2005 Coast Spa (Bronze, Silver & Gold Series) replacement control panel?
@souper soaker how many buttons on topside? post photos
Manual here: https://manualzz.com/doc/6271927/coast-spas---gecko-depot
Generic replacement from Gecko part number  TSC-4-10K / K4...replaces TSC -46
https://pool-spa-supplies.com/gecko-topside-panel-tsc-4-k-4-lg-rec-10-button-real-t-c-3-pmp-mspa-mp-bdltsc410k
I would verify with seller by phone if they actually have it in stock before ordering and also to make 100% sure it will work with your system.
  • Like 1
@souper soaker Ok The generic Gecko replacement is a TSC 19/K 19 that replaces the Coast TSC-34. If you lift up the topside (or look up from underneath) you should see a white tag that identifies the topside. There might be 2 screws under the overlay one on each side. If you feel with your finger you can cut a little x in the overlay and remove them to do minimal damage to the overlay but if you are sure it's pooched then just peel back the overlay.
  • Like 1
https://www.hottubessentials.ca/gecko-spa-controls/tsc-19-4-button-topside-control-panel.html
Located in Kelowna.
Again always phone and verify they have in stock and that it is the correct topside for your system/spa pack. You may be able to find cheaper option online.
2161 Shamrock DriveWest Kelowna BC V4T 1T9Canada(This is not a retail location)
  • 1 month later...
2 hours ago, Detlef Hoffmann said:
Is there a generic control that will fit an Ocean Spa RSC-34 ?
Please start your own thread. Post photos of the pack, Circuit board, Topside and circuit board so we know what you have.
  • 3 months later...
