tanyaB Posted June 24, 2021 Report Share Posted June 24, 2021 HI, We are building a raised interlock deck in our back yard and will be placing our current 7.5 ' x 7.8 ' hot tub in the centre of the deck. Does anyone have any experience building a trap door to access the one side of the hot tub where the access panel is? I have seen the trap doors built into wood decks, but never something that would work with an interlock patio. Please let me know any of your ideas. Thanks Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 30, 2021 Report Share Posted October 30, 2021 Sinking a spa into a deck is always a bad idea in my book. How do you get in...get down on your hands and knees in the snow. Can't use a cover lift in most cases. Not having access to 3 sides is a REALLY bad idea and could be an expensive one if you ever have issue. 2 Quote Link to comment Share on other sites More sharing options...
ratchett Posted November 1, 2021 Report Share Posted November 1, 2021 On 10/29/2021 at 8:36 PM, CanadianSpaTech said: Not having access to 3 sides is a REALLY bad idea and could be an expensive one if you ever have issue. Totally agree, all four sides of the spa should be easily accessible in the event the spa needs to be serviced. Decades ago I had a friend who's dad built a house and put a top of the line Jacuzzi into a "vault" in the patio (literally built the room around the spa). Story goes the tub started leaking after several years, no repairs were possible and no way to remove/replace the tub with a new one. So they boarded up the tub with hardwood flooring. Legends say that tub is still sitting in it's crypt three decades later. 1 Quote Link to comment Share on other sites More sharing options...
broberts Posted November 2, 2021 Report Share Posted November 2, 2021 This forum is full of (far too many) problems that folks have with there tubs. You will likely need access to more than just the service side sooner or later. I agree this not a good plan. Maybe put a removable cedar deck around it Quote Link to comment Share on other sites More sharing options...
cranbiz Posted November 2, 2021 Report Share Posted November 2, 2021 Yes this forum has it's fair share of people who have problems with their tubs. That's why it exists. There are more people who don't have problems of just call a tech. I also agree, building in something that doesn't have access to all sides is not a wise decision. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 2, 2021 Report Share Posted November 2, 2021 I routinely have spas in decks without relief panels built in with leaks or #2 pumps are not always along the front and get the question "how much"... " Well first I will have to make a service call and spend an hour of time disconnecting the electrical from the spa $120 and then I will call the movers and book them in to get it out of the deck $200-$400 and they will also have to come back a second time to place it back into the deck $2-400 once the repair is made but we don't know what needs to be repaired at this point so before I can quote the repair you will be in for between $520-$920 then we can quote the repair once I can get the side panels off and see what's going on. All this might take several weeks depending on how busy the movers are and if you live in say Canada and it's January you don't have several weeks. Even spas up against walls can create problems and require extra help ($$) to move. Had one 2 weeks ago and the repair was a mouse chewed through a 3/8" air line. Spliced in a new section. Cost $3.00. Total cost for the job $640.00 and 10 days. Just say'n 1 Quote Link to comment Share on other sites More sharing options...
