Goplus hot tub Posted June 17, 2021 Report Share Posted June 17, 2021 (edited) The hot tub cut off and when I push the red button it just pops and will not stay on. This is the cord that you plug in Edited June 17, 2021 by Goplus hot tub Quote Link to comment Share on other sites More sharing options...
Cusser Posted June 17, 2021 Report Share Posted June 17, 2021 Sounds like it's picking up a short to ground (like its GFCI is operating properly to protect you) or its GFCI is malfunctioning. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted June 17, 2021 Report Share Posted June 17, 2021 It's most likely the GFCI on the wire. They are notorious for failure. You can buy a replacement cord with a new GFCI for about $15 from Amazon. Or you can just put a male end on the cord and install a GFCI outlet where you plug your spa in. DO NOT use your spa without GFCI protection. To test, yes, you can run it without the GFCI but don't use it. Quote Link to comment Share on other sites More sharing options...
