l33robbo Posted June 15, 2021 Report Share Posted June 15, 2021 Hi peeps, I have the Canadian Spa Swift Current with the V1 PCU, works perfectly without issue BUT! There has been aluminium granules emitting from the heater port for a while which is obviously corrosion/degradation of the heater manifold. Question is... should I be concerned with possible electric shock if somehow the heater electrode is exposed? I'm not sure how the heater electrode sits in the manifold and if it's even possible for the resistive element to become exposed. 🤷♂️ Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 15, 2021 Report Share Posted June 15, 2021 This is why you have a often tested GFCI. You should hit the TEST button on it every now and then to well test it. it is there to protect you from electrical hazards. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 15, 2021 Report Share Posted June 15, 2021 10 hours ago, l33robbo said: aluminium granules emitting from the heater port Aluminum? Are you sure? 10 hours ago, l33robbo said: which is obviously corrosion/degradation of the heater manifold Most heater manifolds are stainless steel, not aluminum. Aluminum should not corrode in spa water. Do you have a salt cell or mineral stick? Describe and post pics of what is coming out. Post pics of heater, circuit board, and equipment area. Describe your chemical maintenance routine including chemicals used and a current water test done with a good test kit, not strips. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 16, 2021 Report Share Posted June 16, 2021 @RDspaguy Post pics of heater, circuit board, and equipment area. Here You go 🤣 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 16, 2021 Report Share Posted June 16, 2021 Oh... I see. 🤪 1 Quote Link to comment Share on other sites More sharing options...
l33robbo Posted June 17, 2021 Author Report Share Posted June 17, 2021 Sorry guys' not getting any notifications of responses. I'll check settings. In response to anyone not taking the p1ss... LOL. Yes I'm pretty sure it's aluminium granules (I'm a MechEng). It may be cheap but it's been churning away for years with only a couple of hickups. I check the Chlorine/PH/Alkalinity on a regular basis so no issues there. Just baffling where these granules are appearing from 🤪 The GFCI is working and I have tested it numerous times recently. CanadianSpaTech... with a name like that you would appear to be the expert on these things 🧐, have you ever heard of anything like this before? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 17, 2021 Report Share Posted June 17, 2021 20 minutes ago, l33robbo said: CanadianSpaTech... with a name like that you would appear to be the expert on these things 🧐, have you ever heard of anything like this before? Sorry No... I have never worked on a one. I don't think you will find many Techs that have. 1 Quote Link to comment Share on other sites More sharing options...
l33robbo Posted June 17, 2021 Author Report Share Posted June 17, 2021 13 minutes ago, CanadianSpaTech said: Sorry No... I have never worked on a one. I don't think you will find many Techs that have. Thanks anyway for your responses 👍 Quote Link to comment Share on other sites More sharing options...
