Mdejesus2 Posted June 14, 2021 Report Share Posted June 14, 2021 I have a 2007 Down East spa Windsor 3 hot tub. I’ve recently changed the heater and on pump that was frozen. Changed all the manifolds (previous owner let it freeze). Got it all set and filled let it prime and not all the keys will work. I turn on jet 1 and it’s really low turn on jet 2 and it’s the same not difference. After a while pump one will shut down and it’s really hot to touch. I have to wait a while for it to kick on again. I’m completely stuck thought I had this all fixed. Help please I’m going insane. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 14, 2021 Report Share Posted June 14, 2021 41 minutes ago, Mdejesus2 said: recently changed the heater and on pump If you change the pump I would be looking at the wiring on the pump Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 14, 2021 Report Share Posted June 14, 2021 Is this the first time the tub has run at that location? Is it on a gfci breaker? Check your incoming power to verify you have 240v red to black and 120v red to white, and they are connected properly at the spa. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 14, 2021 Report Share Posted June 14, 2021 1 hour ago, RDspaguy said: Is this the first time the tub has run at that location? Is it on a gfci breaker? Check your incoming power to verify you have 240v red to black and 120v red to white, and they are connected properly at the spa. Dis regard if you in a Europa. 1 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 15, 2021 Report Share Posted June 15, 2021 That has to be the worst fake accent I have ever heard written. 😉 Maybe post some pics so we know what's going on in there. Include circuit board, wiring diagram, and equipment area. 1 Quote Link to comment Share on other sites More sharing options...
