James67 Posted June 14, 2021 Report Share Posted June 14, 2021 I have an indoor whirlpool tub, and it appears to be leaking from the bottom of the heating box, only when the jets are turned on. Any ideas what this might be and if there might be an easy fix? You can see the water dripping from the bottom of the black box in the photo below. I was thinking of taking the panel off the box to investigate more but am somewhat inexperienced so thought I’d ask for a basic idea of what it might be. Thank you! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 14, 2021 Report Share Posted June 14, 2021 Open it up and look. Post pics. Quote Link to comment Share on other sites More sharing options...
James67 Posted June 14, 2021 Author Report Share Posted June 14, 2021 It has 4 screws on the front of it, which I took off but the front didn’t want to come off (I unfortunately don’t have good access right not to try to remove it further). What is likely to be in the box? The box itself isn’t supposed to fill with water I assume? So something is loose or cracked inside? Thanks so much for the advice! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 14, 2021 Report Share Posted June 14, 2021 Inside the box will be the heater element connections (which may have o-rings) a pressure switch (rubber diaphragm) and who know what else since I have never seen one of those exact systems. If you can't get it open you can't possibly fix it. Unscrew the unions that connect it to the pipes (white ribbed fittings) and take the whole thing out. 1 1 Quote Link to comment Share on other sites More sharing options...
James67 Posted June 15, 2021 Author Report Share Posted June 15, 2021 Thanks so much for the information. That’s a good idea to try to remove it from the pipes. I’ll try that next to see if I can get it open. Really appreciative of the help! Quote Link to comment Share on other sites More sharing options...
