Hot Spring Spa, lcd display not working
Hello, hopefully someone will know whats wrong with my hot tub.
Hot spring model JJ
Serial JJ3L2486
Lights on side of tub green solid, blue flashing,
When i first plugged it up the lcd said "protection mode", only the circulation pump is running.
Any thoughts on what might be wrong or what to start the troubleshooting process would be appreciated.
Mack
2009 phase II Jetsetter.  Phase II just means "Orca" electronics.  If the circulation pump is running but you are still in protection mode it could be one of the sensors on the heater, more likely the hi-limit.  Could also be a temp sensor, a circuit board, low water level, dirty filters, weak flow from the circulation pump.
Remove all filters and make sure the water level is high enough to rule those out.  If you're not wanting to have a service tech come out, the sensors are the cheapest of the parts it could be.
