Water running from here
You will likely have to open it up and see where it goes. Does the spa have a pressurized filter system where you put the filter into a cannister and you have to place the top (see photo) into the cannister and use a lock ring to hold it in place?
Some spas will have a small hole  around the bottom lip of the filter canister to drain away any water if it leaks. It uses suction to suck the water out and can have that gurgling noise
Waterway filter canister parts | Canada
