Rene Johnson Posted June 7, 2021 Report Share Posted June 7, 2021 So my roommates inherited a Hot tub from the previous owners of this property it has a Balboa control system by the make and style of the pool I'm unsure of but we have been trying to get it up and tubbing again so far it's been a pretty good success just wanted some advice on a few things, The pump shuts off after about 5-10 seconds of use and also the Ozonator 3 does not seem to work as well and is it supposed too have a auto shut off when it gets too temperature. oh yes and if anyone could provide me with a legit manual for this make. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted June 7, 2021 Report Share Posted June 7, 2021 Any errors on the topside? Any LED's on the board and if so, what is their status? Post up a picture of the wiring diagram. Can you get a closer picture of the dip switches? Pull the filters and run the spa, let us know if it still runs for 5-10 seconds or if it stays running. 1 Quote Link to comment Share on other sites More sharing options...
Rene Johnson Posted June 7, 2021 Author Report Share Posted June 7, 2021 Only error code is dr that shows up it's a 4 button topside panel it's an older one, there is no LED indicators whatsoever. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 7, 2021 Report Share Posted June 7, 2021 Ahhh The old Canadian made Polar Spa. Went out of business about 10 years ago now. There is a guy in Alberta that has the Polar Spa name but that's about all so finding a manual might be hard. Not much useful information in them any way. Start by removing filters and run without until we get the other issues fixed. Disconnect the ozone until we get the other issues fixed first When it shuts off does it trip the GFCI breaker in the panel? Just before the pump shuts off does it make a buzzing/humming sound? Might be locked up/seized. (My Guess) Let us know and we can go on to the next step. 1 1 Quote Link to comment Share on other sites More sharing options...
Rene Johnson Posted June 7, 2021 Author Report Share Posted June 7, 2021 I've disconnected the Ozone last night it runs and heats up just fine, I've diagnosed the breaker and it doesn't switch off completely but shuts down for 15 minutes then starts up again there is only pumps and no blower I'll take some more pictures and maybe a video of I could upload. Quote Link to comment Share on other sites More sharing options...
Rene Johnson Posted June 8, 2021 Author Report Share Posted June 8, 2021 Unable to upload a video, but I can see that there is a leak under the right nut on the heater, could that be the reason why it is tripping the pumps off? After I disconnected the Ozone the pumps runs longer but still shuts off. Guessing it's a safety feature due to the leak Quote Link to comment Share on other sites More sharing options...
Rene Johnson Posted June 9, 2021 Author Report Share Posted June 9, 2021 On 6/7/2021 at 11:10 AM, CanadianSpaTech said: Ahhh The old Canadian made Polar Spa. Went out of business about 10 years ago now. There is a guy in Alberta that has the Polar Spa name but that's about all so finding a manual might be hard. Not much useful information in them any way. Start by removing filters and run without until we get the other issues fixed. Disconnect the ozone until we get the other issues fixed first When it shuts off does it trip the GFCI breaker in the panel? Just before the pump shuts off does it make a buzzing/humming sound? Might be locked up/seized. (My Guess) Let us know and we can go on to the next step. Yes, I've diagnosed it and it seems to have a leak on the heater nut on the right side so I'm guessing it may be a safety feature that makes it shut down or hopefully nothing too expensive too fix. I unplugged the Ozonoator and it did make a tiny difference, the pumps Ram abit longer maybe 10-15 seconds but turned off again didn't too the breaker and no codes showed up on the panel. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 9, 2021 Report Share Posted June 9, 2021 On 6/8/2021 at 4:39 PM, Rene Johnson said: but I can see that there is a leak under the right nut on the heater, Under the copper tabs the large 19mm nut is that where it is leaking? On the inside of the heater tube but under the large nut there is an o-ring that is part of the heater element so that when you tighten the large nut down to hold the heater element in place it compresses the o-ring for a water tight seal (see attached photo). If the large nut is tight then that 0-ring might have deteriorated. It's a $0.39 o-ring but you might have to replace the heater element (comes with the o-rings) as it might be very difficult to find a replacement o-ring but I would take it to a hardware store and see if they can match it up. If you have a leak there then yes it will cause the breaker to trip as you have water and electricity coming together and the breaker is doing it's job protecting you from electrocution. Replacement heater element is a 5.5 KW offset heater. https://www.poolandhottubdepot.com/titanium-5-5-kw-bowtie-heating-element-with-offset-terminals/ 1 Quote Link to comment Share on other sites More sharing options...
Rene Johnson Posted June 10, 2021 Author Report Share Posted June 10, 2021 On 6/7/2021 at 11:10 AM, CanadianSpaTech said: Ahhh The old Canadian made Polar Spa. Went out of business about 10 years ago now. There is a guy in Alberta that has the Polar Spa name but that's about all so finding a manual might be hard. Not much useful information in them any way. Start by removing filters and run without until we get the other issues fixed. Disconnect the ozone until we get the other issues fixed first When it shuts off does it trip the GFCI breaker in the panel? Just before the pump shuts off does it make a buzzing/humming sound? Might be locked up/seized. (My Guess) Let us know and we can go on to the next step. 23 hours ago, CanadianSpaTech said: Under the copper tabs the large 19mm nut is that where it is leaking? On the inside of the heater tube but under the large nut there is an o-ring that is part of the heater element so that when you tighten the large nut down to hold the heater element in place it compresses the o-ring for a water tight seal (see attached photo). If the large nut is tight then that 0-ring might have deteriorated. It's a $0.39 o-ring but you might have to replace the heater element (comes with the o-rings) as it might be very difficult to find a replacement o-ring but I would take it to a hardware store and see if they can match it up. If you have a leak there then yes it will cause the breaker to trip as you have water and electricity coming together and the breaker is doing it's job protecting you from electrocution. Replacement heater element is a 5.5 KW offset heater. https://www.poolandhottubdepot.com/titanium-5-5-kw-bowtie-heating-element-with-offset-terminals/ It's on the outside of the heater unit in the plastic cover for the right end of the heater nothing to do with it inside, van I just epoxy it and would that be fine for now? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 10, 2021 Report Share Posted June 10, 2021 Ok then the large white coupler at each end of the heater tube? You might just need to tighten the coupler using an oil filter wrench or large channel locks... OR...There is a O-ring Gasket that sits between the chrome tube and the plumbing. You will see 2 screws...one on each side of the coupler...You do NOT need/want to take those out. You will need to spin the entire coupler counter clockwise to loosen it off and you will see the gasket that sits in between that will likely need replacement. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 10, 2021 Report Share Posted June 10, 2021 On 6/8/2021 at 4:39 PM, Rene Johnson said: but I can see that there is a leak under the right nut on the heater, could that be the reason why it is tripping the pumps off? This is not likely the cause of the tripping breaker unless the water dripping is making it's way into the spa pack. 1 Quote Link to comment Share on other sites More sharing options...
Rene Johnson Posted June 12, 2021 Author Report Share Posted June 12, 2021 On 6/10/2021 at 3:38 PM, CanadianSpaTech said: This is not likely the cause of the tripping breaker unless the water dripping is making it's way into the spa pack. No it's not at all more or less dripping completely off to the side, but once I removed the filter I noticed there was a big hole in the manifold under the filter, provided pictures what should be my next step? Quote Link to comment Share on other sites More sharing options...
