Intex Above Ground Pool Pump Replacement Parts
If it's the or-ring between the pump and the wet end (where the skimmer basket is)  it's a SAND FILTER PUMP MOTOR INLET O-RING2  part # 114571. There is a parts diagram in the manual for the pump/filter combo but if you don't have the manual here is a link to it.
https://images-eu.ssl-images-amazon.com/images/I/C1XRD26zxLS.pdf
Intex parts usually have to be ordered from Intex directly:
INTEX RECREATION CORP.
1665 Hughes Way,
Long Beach, CA 90810
1-800-234-6839
(310) 549-2900 :
www.intexcorp.com (U.S./CANADA ONLY)
  • 11 months later...
  • 2 weeks later...
  • 4 weeks later...
On 5/30/2021 at 10:08 PM, jamescgamble said:
Does anyone know what this part is called? It is on an Intex above ground pool sand filter pump, Model sf80110-2. THanks. IMG_4678.thumb.JPEG.26bd1dfffeeeddc60e81aa8a206f43de.JPEG
Did you ever find out what part or where to get a replacement part for this? I’m having the same issue, water trickling out when pump is on. I’m hoping it’s not from the shaft it self.
