RotoSpaz Posted May 30, 2021 Report Share Posted May 30, 2021 Hey All, i have a rotospa that’s about 5 years old and was running fine a few nights ago. Today all the hot tub will do is flash 125. I’m having difficulty finding any documentation to what this code or error would be. I talked to a rotospa dealer and they informed to unplug it for 10 minutes and leave it plugged in for 4 hours, this proved to be unsuccessful. any help here would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 30, 2021 Report Share Posted May 30, 2021 Post photos of the topside control, circuit board and schematic on the inside cover if there is one so we know what you have 1 Quote Link to comment Share on other sites More sharing options...
RotoSpaz Posted May 31, 2021 Author Report Share Posted May 31, 2021 18 hours ago, CanadianSpaTech said: Post photos of the topside control, circuit board and schematic on the inside cover if there is one so we know what you have Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 31, 2021 Report Share Posted May 31, 2021 Does it flash OH then 125? First remove the filters and take them out of the equation. Run without until the issue is fixed. Verify water level is above the filters Verify the heating and filtering related pump is running and moving water in the spa. Post photo of the circuit board Quote Link to comment Share on other sites More sharing options...
RotoSpaz Posted May 31, 2021 Author Report Share Posted May 31, 2021 Hey I’m on the right track. It’s the temperature sensor. I unplugged and everything started working. So I know the issue is my sensor. I’ll trace it out and see what’s going on. Anyone know if this is a thermocouple or a RTD? Quote Link to comment Share on other sites More sharing options...
Bledsoe Posted December 1, 2021 Report Share Posted December 1, 2021 For those that come across this, FYI, RotoSpaz was correct. My spa also flashed 125. No “OH” or overheat on display, it just jumped straight to 125 and nothing would work. Neither pump nor the spa lights would turn on. Unplug the temp sensor from the circuit board and everything would run but the spa would not heat(which makes sense). Bought a new sensor for $40 and it works perfectly again. Very easy fix. I added a pic to show location of my sensor. It was buried under insulating foam but close to the circuit board. Just find where yours is on the inside of the spa first. On the outside the probe is held in place but a plastic collar that unscrews. Also, there’s a rubber O-ring that sits on the probe itself to seal the coupling. Hope this helps someone else Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted December 1, 2021 Report Share Posted December 1, 2021 @Bledsoe you need to cover the back of that sensor with foam or it will detect the temp inside the cabinet. Thanks for the update Quote Link to comment Share on other sites More sharing options...
