Dlawson Posted May 30, 2021 Report Share Posted May 30, 2021 I had to order a new pump my older one has 3 holes for hook up but I was told that they don’t make them like that anymore that they only come with 2 hose hook up for wet end. My question is how do I tee off the hose that was in the top hole like to the input or out put? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 30, 2021 Report Share Posted May 30, 2021 You will have to cut the pipe above the union on the top of the pump and glue in a tee for the other hose. 1 Quote Link to comment Share on other sites More sharing options...
Dlawson Posted May 30, 2021 Author Report Share Posted May 30, 2021 This is the part that screws into the top of pump so where exactly do I need to put the tee? I’m assuming I have to cut the hose/pipe since the valve is on top of the Union am I right or does it need to be done a different way? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 31, 2021 Report Share Posted May 31, 2021 Just cut the hose after the 90, leaving enough to glue the tee onto. The key to any glue job is surface prep. Your pipes are filthy, and should be cleaned thoroughly with pvc pipe cleaner before priming/gluing. 1 Quote Link to comment Share on other sites More sharing options...
