Kbam Posted May 29, 2021 Report Share Posted May 29, 2021 Hi all, I had to replace both the panel head and box on my Vanguard Hot Tub. The old panel was inoperable and they don’t make the old one anymore. I’ve got everything back up and running perfect with one exception- the low speed option for my two jets doesn’t work on either one. I’ve updated the firmware and enabled the low speed option on the screen in the set up. When I press the low speed button I can hear a relay click on, but nothing happens. High speed works great. Not sure if I’ve missed a step or if the new panel and board simply aren’t compatible with the low speed on my tub. Parts I bought... 76836 IQ 2020 Control Box 2012-Current Hot Spring Spas 76844 Control Panel Head, Eagle My serial number: VV1M2187 If anyone has insight, I’m all ears! Thanks! Quote Link to comment Share on other sites More sharing options...
tjr Posted May 29, 2021 Report Share Posted May 29, 2021 Check to see if red low speed wire is on jet 2 low on IQ box, may have put it on jet1low. Quote Link to comment Share on other sites More sharing options...
castletonia Posted May 29, 2021 Report Share Posted May 29, 2021 Assuming everything is wired correctly....... what software version are you running and are all the soft jumpers set correctly? I'm guessing you are running software v 1.14D and if so, soft jumper "J3" needs to be set to "DUAL" for pump 2 to have low speed. Pump 1 will be high speed only. 1 Quote Link to comment Share on other sites More sharing options...
Kbam Posted May 29, 2021 Author Report Share Posted May 29, 2021 The software the parts dealer sent me was 1.10 I believe, sounds like a slightly older version. I’ll grab my screw driver and go check the wiring again. Quote Link to comment Share on other sites More sharing options...
Kbam Posted May 29, 2021 Author Report Share Posted May 29, 2021 Here’s the wiring Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 29, 2021 Report Share Posted May 29, 2021 You have single speed pumps, at least the wiring for single speed. You can't make it run 2 speed as is. If the pumps are 2 speed (unlikely) then you can replace the cord with a 2 speed cord (red, black, white, green). Otherwise you would have to replace the pumps. Quote Link to comment Share on other sites More sharing options...
Kbam Posted May 30, 2021 Author Report Share Posted May 30, 2021 1 hour ago, RDspaguy said: You have single speed pumps, at least the wiring for single speed. You can't make it run 2 speed as is. If the pumps are 2 speed (unlikely) then you can replace the cord with a 2 speed cord (red, black, white, green). Otherwise you would have to replace the pumps. I’ll take your word for it! Could have sworn it was 2 speeds, but I’ve been wrong before. Thanks!!! Quote Link to comment Share on other sites More sharing options...
