Countrygrl Posted May 25, 2021 Report Share Posted May 25, 2021 Hi, we just bought a house that came with a Caldera Palatino which I think is 2014 or older. We cleaned it and also flushed the jets, filled it, added bromine and started it. The next day the display was reading 105 degrees F so I adjusted the temp to 90 degrees. Halfway through the morning the display had 4 double dashes and was unresponsive to my attempts to change anything. The pump is working because I can turn the jets on all 4 settings. What am I missing? We are newbies btw Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 25, 2021 Report Share Posted May 25, 2021 https://www.pioneerfamilypools.ca/wp-content/uploads/resources/hottub-info/4howto/Hot-Tub-Troubleshooting-Guide.pdf See page 27 Remove filters and reset main breakers off and back on. See if that works first. Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 25, 2021 Author Report Share Posted May 25, 2021 Thanks, did all that and replaced the filter after taking it out and still not able to make any temp adjustments although the dashes went away Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 25, 2021 Report Share Posted May 25, 2021 Leave the filters out until the issue is fixed. We need to remove them from the equation completely. What is the current temp at? Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 26, 2021 Author Report Share Posted May 26, 2021 Powered down the hot tub last night and at that time was reading 96 deg F without filter. Going to power up again this morning and check Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 26, 2021 Author Report Share Posted May 26, 2021 93 degrees this morning 1 Quote Link to comment Share on other sites More sharing options...
castletonia Posted May 26, 2021 Report Share Posted May 26, 2021 If water level and filters are not the problem, the two rows of dashes would usually indicate a pressure switch or circuit board problem and the pressure switch would be the more likely culprit. You could try "jumping" the pressure switch to see if the dashes go away. If so, replace pressure switch, if not, then continue troubleshooting. The dashes should not prevent you from being able to adjust the temperature on the display. When the hot tub was reading 105, what was it set for? 2 Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 26, 2021 Author Report Share Posted May 26, 2021 100, yes I think it might be the pressure switch but also a problem with the control panel? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 27, 2021 Report Share Posted May 27, 2021 8 hours ago, Countrygrl said: 100, yes I think it might be the pressure switch but also a problem with the control panel? Probably not both. Won't know until you test the pressure switch. Ready to get your hands dirty, countrygirl? Post a pic of the circuit board and equipment area. Do you have a multimeter? 1 Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 27, 2021 Author Report Share Posted May 27, 2021 Yes but will take the pic and submit when I get home from work! Thanks! RDspaguy!! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 28, 2021 Report Share Posted May 28, 2021 @castletonia, what is that small black piece with the blue wires next to the pressure switch? Is that the high limit? The black square on the heater is the pressure switch. Turn off power and unplug the gray pressure switch cable with the black and red wires from the circuit board. Set your multimeter to the ohm setting and test the two wires for continuity (0 ohms). Then turn on power and pump and test again. Post results. Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 28, 2021 Author Report Share Posted May 28, 2021 Can you please clarify which one is the pressure switch? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 28, 2021 Report Share Posted May 28, 2021 small black square right hand side of the chrome tube has 2 wires attached. Hot Springs Part number 73995 1 Quote Link to comment Share on other sites More sharing options...
Countrygrl Posted May 28, 2021 Author Report Share Posted May 28, 2021 This? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 28, 2021 Report Share Posted May 28, 2021 Yes 1 Quote Link to comment Share on other sites More sharing options...
bpa_wendo Posted July 14, 2022 Report Share Posted July 14, 2022 Hi. .. How did you jumper the Hi Pressure switch? I think I have the same issue. two sets of 4 dashes -- lights work, temperature settings can change, etc... but cycling through jets, only hearing clicks -- pumps never come attempt to come on. Thanks for any feedback!! Quote Link to comment Share on other sites More sharing options...
