Zach
Time to start the troubleshooting process.  My experience is limited to my hot tub (Dream Maker), but yours should be similar I assume.
Open the access panel to the "guts" of the spa. Locate the control pack that contains the control board.  Take a picture of the wiring diagram and upload it here. (Learned that one from RDspaguy)
And then if I were you, (with power off at the breaker) I'd unplug all cables plugged into the control circuit board, then plug them in one by one, restoring and disconnecting power between each test to see which component was affected by the water.
