Alber36 Posted July 3, 2021 Author Report Share Posted July 3, 2021 2 hours ago, CanadianSpaTech said: @RDspaguy AGREED INDEED! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 3, 2021 Report Share Posted July 3, 2021 Aww, schucks... ☺️ Quote Link to comment Share on other sites More sharing options...
Alber36 Posted July 4, 2021 Author Report Share Posted July 4, 2021 @RDspaguy Hopefully my final question: I noticed with this new system when the spa is idle for a while and I open the cover, the temperature is not displayed, there are instead 4 dashes. I click the pump on and the temp is then displayed and in range of the set temp. I checked the manual and all it says for the dashes is: “water temp unknown- after pump runs for 1 minute, temp will be displayed.” Is this normal to show up every time the hot tub is idle for a while? I’m just not used to seeing this as the prior system always displayed the temp, no matter how long it was idle. Not sure if it means I may have an airlock or some other issue... I did empty and refill the tub yesterday. Thank you! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 5, 2021 Report Share Posted July 5, 2021 I have never seen one of these so couldn't say. Is it in economy mode or something? Quote Link to comment Share on other sites More sharing options...
Alber36 Posted July 5, 2021 Author Report Share Posted July 5, 2021 @RDspaguy No, it’s in ready mode… Quote Link to comment Share on other sites More sharing options...
cranbiz Posted July 6, 2021 Report Share Posted July 6, 2021 Yeah, That's normal. My brand new Island Spa does the exact same thing and it also has Balboa controls. 1 Quote Link to comment Share on other sites More sharing options...
Alber36 Posted July 6, 2021 Author Report Share Posted July 6, 2021 @cranbiz Great, thank you!! Quote Link to comment Share on other sites More sharing options...
Enrique Posted September 29, 2021 Report Share Posted September 29, 2021 On 5/19/2021 at 2:01 PM, RDspaguy said: Those are 2 of the three relays controlling the heater. The single thermostat relay is the one that fails, as it is the one that switches on/off during normal use. They are soldered to the board, hence the need for an electronics guy. If your repair guy doesn't know this, he is not an electronics repair guy. Perhaps you should just buy a new board. It sounds like the guy you are talking to doesn't know what the **** he is doing. @RDspaguy Which one is the thermostat relay in the board? (K1, K3 or K5)? I'm guessing it's one of the three that are close to the heater terminal Thanks! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted September 30, 2021 Report Share Posted September 30, 2021 Not sure, I don't do circuit board repairs. I'd get all the relays replaced, even the pump relays, if I were getting it done. 1 Quote Link to comment Share on other sites More sharing options...
Enrique Posted September 30, 2021 Report Share Posted September 30, 2021 1 hour ago, RDspaguy said: Not sure, I don't do circuit board repairs. I'd get all the relays replaced, even the pump relays, if I were getting it done. Thanks, if you were to guess: are the pump ones the small ones or still the big ones?, I'm guessing K2, K6? I'm having a similar problem as stated in this forum. Instead of no heat - I get very little heat only 2-3 degrees every eight hours. Reading 0V between heater terminals and the resistance when connected seemed ok. I got a hot tub tech checking it for me and he recommended a replacement for the board. So I was going to swap the relays myself before swapping the entire board. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 1, 2021 Report Share Posted October 1, 2021 That is no heat. And if there are no error codes and you are not in sleep mode, it is a bad relay or connection. Unplug it and test at the board pins, they are notorious for failing. Otherwise, start your own thread and include pics of your circuit board and equipment. 1 Quote Link to comment Share on other sites More sharing options...
Enrique Posted October 19, 2021 Report Share Posted October 19, 2021 On 9/30/2021 at 10:20 PM, RDspaguy said: That is no heat. And if there are no error codes and you are not in sleep mode, it is a bad relay or connection. Unplug it and test at the board pins, they are notorious for failing. Otherwise, start your own thread and include pics of your circuit board and equipment. Just posting an update. I ended up replacing all the 5 relays in the main board (HF2150-1A-12DEF) as suggested ($1.12/relay fix). It got fixed, I can read voltage on the 2 terminals of the heating element and the hot tub has warmed up tot he correct settings. My guess is that it was the two Hongfa relays near the heating element port. But replaced all 5 just in case. Thanks for the help! 2 Quote Link to comment Share on other sites More sharing options...
gus85 Posted January 6 Report Share Posted January 6 Balboa swim spa. My spa is below 7 degrees celsius now and in some places it has frosen pipes. its now -14 celsius in Sweden at the moment :) my problem is that to heat up the pool the jetpumps must be on, and that makes my fuses in the house go off. so i cant leave for several hours to get the temp up because to get the temp up because the jetpumps must be on until it reaches above 7 degrees Celsius. my question is - is it any other way to just heat up the pool without the 3 jetpump bursting in full mode? i baught a heater Wich i can dip in the spa but it takes 5 more days to get it to my adress. regards / Gustaf Quote Link to comment Share on other sites More sharing options...
