zich6 Posted May 11, 2021 Report Share Posted May 11, 2021 I took great care of the tub this winter in North Idaho, but I just noticed pump 3 is not turning on. Are there any trouble shooting steps I can take (manual says bupkis) before I call a technician? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2021 Report Share Posted May 11, 2021 Check/test the fuses first (the large ones that say SC25 or SC30 on them) If you can access the pumps backside there is a dust cover dead center at the back of the motor. Remove the cover and you will see a slot in the shaft of the motor where you can place a flat head screwdriver in and try and see if it turns freely or if it is stuck/seized. 1 Quote Link to comment Share on other sites More sharing options...
zich6 Posted May 12, 2021 Author Report Share Posted May 12, 2021 Turns out I inadvertently put the controller in setup mode and assigned the pump 3 button to flip screen. All fixed and done. Thanks. 2 Quote Link to comment Share on other sites More sharing options...
