Jfsgrl2006 Posted May 10, 2021 Report Share Posted May 10, 2021 Help!! The heater on our 2011 Dream maker hot tub went out, and of course it is now discontinued, the replacement they said to use is way to big the original is 6 inches and the replacement is 10, there is not enough room in the hot tub for it. I attached the heater we have now .. Thank you, we have replaced everything else in this thing. A $200 purchase is now over 1000, so I don’t want to just get rid of it.. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 11, 2021 Report Share Posted May 11, 2021 https://www.spaguts.com/products/spaguts-universal-inline-bath-heater-kit-1-5kw-110v-1-5-inch-3794.aspx?gclid=Cj0KCQjws-OEBhCkARIsAPhOkIbLmPN_y9tQKgz8OjmLfID5txIIUDQrraMJ8Hc4QwH7mSt4vnPVV-YaAivpEALw_wcB#ConfigSelection 7in is as close as I can find. Quote Link to comment Share on other sites More sharing options...
Jfsgrl2006 Posted May 11, 2021 Author Report Share Posted May 11, 2021 53 minutes ago, RDspaguy said: https://www.spaguts.com/products/spaguts-universal-inline-bath-heater-kit-1-5kw-110v-1-5-inch-3794.aspx?gclid=Cj0KCQjws-OEBhCkARIsAPhOkIbLmPN_y9tQKgz8OjmLfID5txIIUDQrraMJ8Hc4QwH7mSt4vnPVV-YaAivpEALw_wcB#ConfigSelection 7in is as close as I can find. And I can install this on my hot tub? thank you for your help by the way. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 11, 2021 Report Share Posted May 11, 2021 Probably. It is a 1.5kw and yours was a 1kw, so there will be a higher amp draw. I could not find a 1kw. How many amps does your pump draw and what size breaker is it on? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2021 Report Share Posted May 11, 2021 This might work: https://www.ebay.ca/itm/124101060983?chn=ps&norover=1&mkevt=1&mkrid=706-89093-2056-0&mkcid=2&itemid=124101060983&targetid=885167349563&device=c&mktype=pla&googleloc=1002347&poi=&campaignid=9561945102&mkgroupid=98506997979&rlsatarget=pla-885167349563&abcId=1063836&merchantid=137621537&gclid=CjwKCAjw1uiEBhBzEiwAO9B_HdkduRmWRDPJLWo9vIXXIYqWEgrubM6w7GDi0b5NoKyDTMcwro-QFBoC2bkQAvD_BwE Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 11, 2021 Report Share Posted May 11, 2021 That is the same one I listed. It is also 1.5kw (1500 watts) and is set up with a vacuum switch (uv in part number) so it would have to be on the suction side of the pump not the pressure side. The link I provided lists both pressure and suction side heaters. Order the right one. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 11, 2021 Report Share Posted May 11, 2021 2 hours ago, RDspaguy said: That is the same one I listed. It is also 1.5kw (1500 watts) and is set up with a vacuum switch (uv in part number) so it would have to be on the suction side of the pump not the pressure side. The link I provided lists both pressure and suction side heaters. Order the right one. Oh so now I gotta open the links your posting as well...lol. I just looked at the pic on Ebay...it looked like 6"... never seen one that small.. lol Quote Link to comment Share on other sites More sharing options...
