Hot tub overflowing when pump is running for pool
Hi -
I have an inground pool and separated (but connected) inground spa. The spa is a few inches higher in elevation than the pool. They are running off of the same pump/equipment. I have an issue where spa is overflowing when pump is running for the pool. When finished, the spa then drains to a level equal to the pool (which is too low). Is this a check valve issue - if so I am not clear if I have one or where it's located? Is an adjustment needed in the Jandy valves?
I have attached picture of pool and plumbing/equipment layout.
Thx
Scott
IMG_1944.HEIC IMG_1945.HEIC IMG_1946.HEIC
Link to post
  • 3 weeks later...
Or a clog/restriction in the overflow pipes from the spa to the pool? Do you have overflow lines to the pool?
There should be a check valve in the return line back to the spa (If that is the design). Or perhaps the spa is supposed to run independent every day (for a short time) isolated from the pool to keep it clean.
Did you just buy this house?
A picture from the other direction may help (taken from the heater end) to show the return valve better.
Link to post
