Andy Fox Posted May 8, 2021 Report Share Posted May 8, 2021 Hi we have a new large doughboy above ground pool which we are partially sinking in to the ground. We have a heat pump but I am concerned the return pipe position is to close to the skimmer and the water won’t mix. Is it usual to relocate the return pipe. Worried this may void my warranty. But I am sure if I don’t half my pool will be cold. Quote Link to comment Share on other sites More sharing options...
Cusser Posted May 8, 2021 Report Share Posted May 8, 2021 I have a 15 ft above ground pool, and use an inexpensive solar cover in spring and fall. The sunlight heats the upper top foot of the water, but the pump comes on with my timer and does a decent job mixing it. Quote Link to comment Share on other sites More sharing options...
