Joseph2 Posted April 30, 2021 Report Share Posted April 30, 2021 So I am sure that I can make the repair myself I am just not sure what all the parts are that I would need. I thought that I would be able to pull the plug type thing in the t out but I was not able to as it it glued in. So that means I will have to cut from the large flex pipe and replace all the pvc. The items that I don't know are called are the T itself since that looks like a smaller size coming out the top, and the piece that fits into it. I know that it had a reducing nipple coming out the top as that is what connected to the clear piping. Could someone tell me what those parts are called so that I can buy them? Thanks! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 30, 2021 Report Share Posted April 30, 2021 http://elmsalesandequipment.com/product-catalogue.htm Reducing Tee 2" x 2" x 1"...page 60 Barb Adapter # 10 page 62... I am assuming the line coming off the Tee is 3/8" hose 2" coupling sxs page 59 2" pump union Sweep Ell 45 degree.. page 98 Ell 45 street s x spg... page 58 1/4 pint 725 glue page 67 you will also need a 6-10" piece of 2" flex or ridged tubing/hose. When you cut the flex hose you will be 3" to short so you need to add the 2" coupling to the flex and have the other end of the added hose go into the Tee. You have to be exact so it mates up with the pump true and flush or it won't seal to the pump so start by putting the pump union on first and work your way back to the flex. Always good to dry fit before glue if possible. The glue I posted dries instantly so you have to be sure and you have to be quick to align it all up properly. 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 30, 2021 Report Share Posted April 30, 2021 https://pool-spa-supplies.com/lasco-pvc-fitting-tee-2-slip-x-2-slip-x-1-2-slip-401-247 https://pool-spa-supplies.com/waterway-plastics-barb-adapter-1-2in-spg-x-3-8in-barb-425-0210-18198 https://pool-spa-supplies.com/aqua-flo-inc-2in-pump-union-45-degree-tailpiece-52202020-2458 https://pool-spa-supplies.com/dura-45-elbow-dura-2-spigot-x-2-slip-423-020 https://pool-spa-supplies.com/dimension-one-2-pvc-coupler-s-x-s-01420-19-5426 You will also need a short piece of 2" pvc or spa flex and glue and primer. I prefer Christy's red hot blue glue. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 30, 2021 Report Share Posted April 30, 2021 Is there an echo (echo... echo...)? Quote Link to comment Share on other sites More sharing options...
Joseph2 Posted May 1, 2021 Author Report Share Posted May 1, 2021 You guys rock thank you!!! 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 1, 2021 Report Share Posted May 1, 2021 Yes. Yes, we do. 😉 1 Quote Link to comment Share on other sites More sharing options...
