Sam12345 Posted April 30, 2021 Report Share Posted April 30, 2021 My hot tub is arriving in a few weeks. After previously assuming my patio was level, I have now discovered it has a 17mm slope across the width of the tub (2.2m). the supplier recommended a minimum of 5-10mm slope and has therefore suggested putting a base in to ensure their warranty isn’t invalidated. Seems a lot of trouble to go through for a minor slope but I’ve never owned a hot tub before. Any recommendations? Would it be very noticeable on the water level? many thanks! sam Quote Link to comment Share on other sites More sharing options...
cranbiz Posted April 30, 2021 Report Share Posted April 30, 2021 5/8" over about 7.25' for us English unit people. That's really not much. Where any issues would be is if the water level would be below the filter when filled. Somehow, I don't see that being a problem. If you do have to fix it, a quick way is to build a quick frame around the final resting place of the tub and mix up some self leveling cement. I used the Mapei cement found in the flooring section of Lowes. $30 USD for a #50 lb bag, which covers 48 sq-ft at 1/8" thickness and one qt of primer, $12 which should cover the entire surface to be leveled. My slope was a lot worse, close to 2" over 9' and I was leveling a 80"x108" pad, I'm pretty sure I used 3 bags of cement and 1 qt of primer. Mix it to a pourable consistency, pour it in and let it set for 24 hours. It's really quick and easy. Just make sure your frame is sealed to prevent it leaking thru. A bead of caulk will take care of that. 1 1 Quote Link to comment Share on other sites More sharing options...
funky_duck1066 Posted May 5, 2021 Report Share Posted May 5, 2021 Cranbiz curious how this turned out. I have about a 1.75 in (44mm) slope over the length of my tub that I feel needs corrected. Did you permanently add a section of "corrected" self leveling cement to an existing patio, only large enough for the tub? I'm wondering if plastic could be placed underneath so you are effectivley creating a large cement shim. Pics would be great, thanks. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted May 5, 2021 Report Share Posted May 5, 2021 This is an enclosed patio with a terra cotta mosaic surface. The entire floor is sloped 2.75" over 12'. I permanently affixed the mine to the slab. Filled the large areas with quickrete and then after that set, primed and poured the self leveling cement. I make the correction slightly larger than the published footprint of the tub. The difference between the existing patio and the new, leveled pad I used Grout to ease the angle and prevent stubbing your toes and built a trex deck section at the end where we will enter and exit the tub. You could use a thick plastic, I'm sure to keep from permanently bonding to the existing surface. I suspect the downward friction would keep it in place. With any luck, by next weekend, my tub will be here and installed. 1 Quote Link to comment Share on other sites More sharing options...
Couch67 Posted April 1, 2022 Report Share Posted April 1, 2022 . Quote Link to comment Share on other sites More sharing options...
