RonGriffin2 Posted April 28, 2021 Report Share Posted April 28, 2021 Our inground fiberglass spa has popped out of the ground. We had it fixed once since we moved in 7 years ago and at this point want to remove it and purchase an above ground. My question is if I want to remove the tub, can I cut it out without affecting the rest of the pool operation? We have 4 separate valves for water coming into the pump (spa, vacuum, main and skimmer) and 3 returns (spa, stairs and returns). I am assuming I would also need to re-pipe these to stop water from going to the spa returns and incoming water. Quote Link to comment Share on other sites More sharing options...
Cusser Posted April 28, 2021 Report Share Posted April 28, 2021 8 minutes ago, RonGriffin2 said: My question is if I want to remove the tub, can I cut it out without affecting the rest of the pool operation? We have 4 separate valves for water coming into the pump (spa, vacuum, main and skimmer) and 3 returns (spa, stairs and returns). I am assuming I would also need to re-pipe these to stop water from going to the spa returns and incoming water. I cannot see any reason why you or a plumber could not close off or bypass such spa. 1 Quote Link to comment Share on other sites More sharing options...
