alcam42 Posted November 26, 2005 Report Share Posted November 26, 2005 I have the option of buying the Caprio on sale (floor model) or spending another $1500 for the Marin. What is the benefit of having 1 pump vs 2 pumps? Also the pumps in the Marin are larger does that add a lot more power for the jets. I can use all the advice anyone can offer. Quote Link to comment Share on other sites More sharing options...
AZJohn15 Posted November 26, 2005 Report Share Posted November 26, 2005 I have the option of buying the Caprio on sale (floor model) or spending another $1500 for the Marin. What is the benefit of having 1 pump vs 2 pumps? Also the pumps in the Marin are larger does that add a lot more power for the jets. I can use all the advice anyone can offer. I recently purchased a Caprio and am really enjoying it. I needed one that could run on 110V, so the Caprio is perfect. With 2 pumps, you should be able to use the jets in all of the seats at once where in the Caprio, you use a diverter valve to select which jets are in use. For one or two people that's no problem, if you have a full tub in might be inconvienient. Higher hp pumps should also give you more power, but for me, the Caprio has plenty. I find the seats in the Caprio very comfortable, especially the Adirondack chair. Your best bet would be to wet test them both if possible. Good luck! Quote Link to comment Share on other sites More sharing options...
