pebbleridge Posted April 14, 2021 Report Share Posted April 14, 2021 Hi Guys, Our Hot Spot Sorrento (2004) is still going but...... The pump seems very noisy, I'm sure it was not this noisy a few years ago. Apart from replacing the pump, could it be anything else? Regards, Paul Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 14, 2021 Report Share Posted April 14, 2021 Define "noisy". There are a bunch of things that can make a pump loud, from flow restrictions to motor bearings to stuck relays. Quote Link to comment Share on other sites More sharing options...
pebbleridge Posted April 15, 2021 Author Report Share Posted April 15, 2021 Hi RDspaguy, It's definitely not a stuck relay type of noise, more a physical noise. I'm getting the same movement of water from the Jets, so I don't think it's a flow restriction. I'm presently trying to get the inspection panel off, then perhaps I might be able to get a better idea of where it's coming from. Paul Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 15, 2021 Report Share Posted April 15, 2021 So, a grinding noise would you say? Probably motor bearings. An electric motor shop can take care of that. Quote Link to comment Share on other sites More sharing options...
pebbleridge Posted April 17, 2021 Author Report Share Posted April 17, 2021 Hi RDspaguy,, Thanks for the advice, when I get the cover off, I'll try holding a piece of wood against the pump and put the other end to my ear. I should be able to confirm that the motor bearings are grinding. Regards, Paul Quote Link to comment Share on other sites More sharing options...
pebbleridge Posted April 20, 2021 Author Report Share Posted April 20, 2021 Hi RDspaguy, Sorry to bother you again. I've managed to get the cover off (My tub is sunk into the deck, I had to remove some deck boards before I could get it off), but I can't see a pump in there. I've got the controller mounted onto a metal pipe, which I think contains the Heater, but there is no sign of a pump. I don't think I've got another access cover. Regards, Paul Quote Link to comment Share on other sites More sharing options...
