Hi folks I'm looking for some help. I have recently bought this item
https://www.lay-z-spa.co.uk/underwater-led-light.html
It is supposed to screw into the debris screen for the Hawaii model, my issue is I cannot remove my screen. I have tried all sorts of tools including a plumbers wrench. Any suggestions?
TIA
  • 1 year later...
  • 1 year later...
just figured this out. Turn the chem filter to take it off and the debris filter (shield) is under this. Unscrew the debris filter and screw the light back into the threaded hole this debris filter came out if. You need to replace the debris shower and chem chem filter when you get back out of the spa.  sort of a nuisance but Only takes a minute…
  • 5 months later...
Hade the same issue. At first thought I bought wrong part. I tried needle nose pliers and stopped as I was getting no movement and didn't want to break plastic or worse slip. My wife actually came to the rescue here. Rubber pickle bottle opener. Came off in a jif.
