Christine9 Posted April 6, 2021 Report Share Posted April 6, 2021 I had a leak in my hot tub and repaired it however the patch needs replaced and repaired again. What is the best way to do this Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 7, 2021 Report Share Posted April 7, 2021 9 hours ago, Christine9 said: I had a leak in my hot tub and repaired it however the patch needs replaced and repaired again. What is the best way to do this Then you did not repair it, you put a bandaid on it. Now you are in the position where a bandaid is not an easy option any longer, and you need to repair it. You would have to remove the old "patch" and redo it. How to do that depends on what you used and what you put it on, but is never easy in any case. Post some pics of the leak so we can see what you've got going on there. Quote Link to comment Share on other sites More sharing options...
