Variable Speed Pump, Low and High Mode
Hello. I just got a VSP and I noticed something strange. When my pump goes into the Low RPM mode at 1500 RPMs, the flow goes to 0 GPM (what it reads on the pump) but I haven't lost the priming function. Is this ok? What is the ideal flow rate for the Low RPM mode? I have solar pool panels that the water goes through. Any advice will help.
Thank you!
  • 2 weeks later...
