Mike Shelby Posted March 29, 2021 Report Share Posted March 29, 2021 I have and Artisian Waikiki Elite tub about 6 years old. Recently circuit breaker started tripping. When turn back on it would trip again once tub pumps started up. It has all Balboa components. By process of elimination I found it was pump one. When jet pump 1 (out of 3) started the breaker would trip. I tested my theory by unhooking pump from control board over and over. I had a local shop test the pump and it is fine. I noticed when pump 1 was plugged in as 2 or 3, it was fine. When I plugged other pumps in as pump 1 then breaker would trip. Seems to me this points to circuit board or control panel(?). There is no water damage that I can see. Has anyone seen this issue? Is anything on the control board serviceable? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 29, 2021 Report Share Posted March 29, 2021 It's the heater, which can only work if pump one is running. Quote Link to comment Share on other sites More sharing options...
