2007 - 'Umbria' Spa, needs new Topside - help required to identify what I can fit?
We have a Hot tub that came with the house we purchased.
Generally all ok, but the controls have never had an overlay.
It has buttons that seem to be;
'Pump or Jets' on   / Lights On   /  Temp Increase   /  Temp decrease
There are Leds under that show when the Pump or Lights or Heaters are on.
The Topside is 110mm wide approx.  x 40mm Oval
I can see that the control plugs in onto the main PCB. This is marked GS Series.  Model - MGS500Z
My question is, what new unit can I use to replace the current Topside ?
Looking at  Balboa info, it seems I would need a VL200 - 4 button model 118852
Searching the internet doesn't bring any up for sale, so could I use another model ?
Can I use a Topside with only 1 Temp button? Would the main PCB recognise other button versions and work correctly?
Thanks in advance
Joe
