Jack55 0 Posted March 10 Report Share Posted March 10 Before the freeze in Texas a few weeks ago, I "winterized" my pool equipment by removing the filter, pump, and heater "plugs" and drained the system. After the freeze, I replaced the plugs, primed the pump and started up the system. Everything works, except the Jandy JXi gas fired heater took 4 hours to heat the spa section of the pool from 68 degrees to 104. The heater never cycled on and off; it ran continuously until the temp was reached, and then it shut off. Before the freeze, the spa heated to 104 in 30-40 min. What could the issue be, and how do I fix it? Show less REPLY Quote Link to post Share on other sites
RDspaguy 728 Posted March 11 Report Share Posted March 11 @jimmythegreek, any ideas? Quote Link to post Share on other sites
jimmythegreek 31 Posted March 14 Report Share Posted March 14 Double check that you valves are activating properly. This issue usually is a result of either the powered valves or a manual valve not keeping the spa isolated. If that is 100% not the issue then likely a gas issue whether pressure or low flame output 1 Quote Link to post Share on other sites
