WickedTub Posted March 8, 2021 Report Share Posted March 8, 2021 So finally got all my stuff to convert to bromine.. should I wait for my chlorine levels to drop below 1 to start... also once I add the sodium bromide for the reserve bank and then shock and add tablets to my sundance bromineator what levels do the bromine need to come down to before its safe for my family to use the tub? And how long should that take to come down.. thanks in advance Edit: how many tablets should I start with if my tub is about 390 to 400 gallons? 4? Quote Link to comment Share on other sites More sharing options...
waterbear Posted March 16, 2021 Report Share Posted March 16, 2021 On 3/8/2021 at 12:11 PM, WickedTub said: should I wait for my chlorine levels to drop below 1 to start no, if you add sodium bromide into a chlorine tub you have a bromine tub almost instantaneously but I would shock it first so the bromine is above 10 ppm. Wait until the bromine is below 10 ppm before entering. then add your floater and adjust it to maintain 4-6 ppm of bromine. Number of tablets should not matter but how open or closed you have the floater does. I usually recommend 3 or 4. 1 Quote Link to comment Share on other sites More sharing options...
