qwertyjjj Posted March 6, 2021 Report Share Posted March 6, 2021 I've found a used jetpack 941100 pack but it doesn't have a topside controller. It has a mounted Johnson a419 but that seems to only do the temperature. Are topside controllers generally compatible with all packs or do you have to buy one by the same manufacturer? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 6, 2021 Report Share Posted March 6, 2021 Same Manufacturer and has to be compatible with the spa pack circuit board and even then it could be chipped proprietary the SPA manufacturer. You could have 2 identical LOOKING circuit boards but would require 2 different topsides. 2 Quote Link to comment Share on other sites More sharing options...
qwertyjjj Posted March 6, 2021 Author Report Share Posted March 6, 2021 Is it possible to make the pump work without the topside? I'm assuming it has its own on off switch. I can't figure out why this one has a separate Johnson a419 controller mounted on the side of the pak. It's like it has a separate controller that only does the temperature but doesn't control anything else. I can only find this info on it https://www.poolsupplyunlimited.com/pool/johnson-controls-a419-series-electronic-temperature-control-13-ft-lead-cord-a419abc-3c/136031p1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 9, 2021 Report Share Posted March 9, 2021 You know, @CanadianSpaTechlives up there in the frozen wastes like you. Perhaps he knows where you might acquire a used tub in need of repair. 1 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 9, 2021 Report Share Posted March 9, 2021 Where are you lpcated? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 9, 2021 Report Share Posted March 9, 2021 4 hours ago, CanadianSpaTech said: Where are you lpcated? Quebec, according to his profile on another forum he posted on. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 9, 2021 Report Share Posted March 9, 2021 41 minutes ago, RDspaguy said: Quebec, according to his profile on another forum he posted on. Be honest...did you know how to spell Quebec or did you have to look it up...lol Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted March 10, 2021 Report Share Posted March 10, 2021 I got it right? 😉 I know you couldn't tell from my posts here, but I actually have quite an extensive vocabulary and have always excelled at spelling. I can also spell antidisestablishmentarianism and deoxyribonucleic acid, as well as potassium peroxymonopersulfate and xylophone. I know... shocking, right? I have learned not to utilize the full breadth of my linguistic capabilities, as some people are disconcerted or even perturbed by their own perceived condescension in my blithe and occasionally flippant use of vocabulary. But I digress...🤣 1 Quote Link to comment Share on other sites More sharing options...
