goltho2 0 Posted February 22 Report Share Posted February 22 Good morning, thanks for the add. I have a 2008 Catalina Premium 800CD (UK version of the Quebec) which has semi-died. The top panel appears to be responding correctly in that the display is fine, Mode settings changes appear to be saved, the pump/blower/lights buttons show and hide their yellow lights when pressed, and the fast-flicker heater activation light is working. The commands however are not being actioned, i.e. both pumps, the blower, the lights and the heater do not operate. I've cut power for 12 hours and restarted but to no avail. I've also tested all fuses which are good, and power (240v) is getting to the board. I have plenty auto-electrical and domestic appliance experience although not hot tubs, and suspect the board. Is there anything else to check on the basis of what I've reported? Any and all help will be much appreciated. Thanks. Quote Link to post Share on other sites
CanadianSpaTech 424 Posted February 22 Report Share Posted February 22 Did you remove the fuses to test or did you test in place? Remove and Retest all the glass fuses F2, F4 1 Quote Link to post Share on other sites
goltho2 0 Posted February 22 Author Report Share Posted February 22 3 hours ago, CanadianSpaTech said: Did you remove the fuses to test or did you test in place? Remove and Retest all the glass fuses F2, F4 Thanks for the response. I actually watched that vid on YouTube earlier. I did remove all the (6) fuses after testing in place as I figured I might get false readings. They're fine. I also spoke with an engineer briefly to run it past him, and he was 90% of the opinion that the panel would be faulty given the absence of error messages but also of any relay clicks with all button options. He has had this issue himself a few times. I've now removed the panel to identify it, and it's an ML554. I'm contemplating buying another panel (probably eBay) to test and (hopefully not) return if it doesn't resolve the issue. Unfortunately there are currently none available here in the UK. 🙄 Is there anything else I can be checking meantime? Quote Link to post Share on other sites
CanadianSpaTech 424 Posted February 22 Report Share Posted February 22 If you disconnect the topside will it run basic functions...pump 1 low and heat? Is there a remote/Aux topside 1 Quote Link to post Share on other sites
RDspaguy 646 Posted February 23 Report Share Posted February 23 A faulty button, even an auxiliary button, can cause control issues. As can damaged wiring. I would unplug any auxiliary control, check main control wires for rodent damage, and unplug main control to test automated functions. Also check board for dark spots. Post a pic of board. 1 Quote Link to post Share on other sites
