Angelina Posted February 19, 2021 Report Share Posted February 19, 2021 I am getting conflicting information about the way to measure the radius for a spa cover. I have a Evolution Essence by Strong Spas, that has a 3 tier lip. Where should the measurements be taken? I’ve included a pic. Quote Link to comment Share on other sites More sharing options...
Peels Posted February 19, 2021 Report Share Posted February 19, 2021 The place I ordered (I forget) told me exactly where to measure. I think it was an inch inside from the beginning of the corner curve. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 19, 2021 Report Share Posted February 19, 2021 Put the square up against the original cover and confirm it against the spa. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted February 20, 2021 Report Share Posted February 20, 2021 Measure the spa right were you did in the pic. If you measure the cover and send those measurements your cover will be too big. Most cover manufacturers can build your cover with brand, model, and year of spa. 1 1 Quote Link to comment Share on other sites More sharing options...
Angelina Posted February 20, 2021 Author Report Share Posted February 20, 2021 14 hours ago, CanadianSpaTech said: Put the square up against the original cover and confirm it against the spa. I don’t currently have a cover. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 20, 2021 Report Share Posted February 20, 2021 8" radius. You will also need to measure the side skirt. Top of the acrylic down to bottom lip of acrylic. I will usually add 1/2" to that measurement for a little overhang and also a spot to grab it to pull it tight/down. 1 Quote Link to comment Share on other sites More sharing options...
Angelina Posted February 20, 2021 Author Report Share Posted February 20, 2021 12 hours ago, RDspaguy said: Measure the spa right were you did in the pic. If you measure the cover and send those measurements your cover will be too big. Most cover manufacturers can build your cover with brand, model, and year of spa. I don’t currently have a cover.. I have tried the manufacturer that can’t speak with anyone...hold,...voicemail,... I will try again. But if that’s were I need to measure, not the top tire, then I can place an order with someone else. Thank you Quote Link to comment Share on other sites More sharing options...
