dobeleye 0 Posted February 19 Report Share Posted February 19 Help! New hot tub owner and we can’t seem to balance the water and can’t figure out why. Every evening, we’re able to get the chemicals in balance and everything seems fine. But every morning, the ph is sky high 8.4 and there is zero bromine in the tub. I tried shocking it yesterday with non chlorine shock after adjusting the ph, and that worked - but again only for a few hours. We are using the spa frog system to add bromine to the tub, but the ph levels seem to be consistently high and the bromine levels consistently nonexistent each morning. What are we doing wrong and how can we fix it? Quote Link to post Share on other sites
RDspaguy 629 Posted Saturday at 12:57 AM Report Share Posted Saturday at 12:57 AM I suggest you search the chemistry section for "bromine" and "ph", and read a bit. Come back with any questions. Use Ahhsome spa plumbing cleaner on any new-to-you spa. Quote Link to post Share on other sites
