heygreene 2 Posted February 16 Report Share Posted February 16 Hi all, we just received our new Nordic Escape SE and the family is loving it. With that being said, there were no Nordics around to wet test, so we bought it without sitting in it. First impressions are the size is good for our family of 5 (wife and I, and our 12, 10 and 5yo kids), and we could probably put one or 2 other kids or maybe 1 more adult in with no issues, so that is a good thing. The whirlpool on high will almost blow you out of the seat, it's super intense. However, when we turn it to one side or the other it's "okay" (not a huge amount of pressure coming out, but you can feel some massaging... kinda feels like what I would expect it to feel like on low). When it's on both sides, you can barely even feel anything at all... absolutely no pressure/massaging, just warm water moving around. I'm assuming this is normal for a 1-pump HT, but figured I'd ask before I called Nordic or my local dealer. In hindsight I should have probably purchased the LS to get the 2 pumps but there was no ETA on when those were coming in, and I figured I wouldn't need it. This is likely a mistake on my part being a first time spa buyer... lesson learned. Is there any "help" for this? I'm assuming "it is what it is". Thanks, Heygreene Quote Link to post Share on other sites
Raskm42 1 Posted February 17 Report Share Posted February 17 I owned the Nordic retreat SE and while it was a nice dependable hot tub it doesn't have near the pressure of my new Hot Springs. 1 Quote Link to post Share on other sites
heygreene 2 Posted February 17 Author Report Share Posted February 17 15 hours ago, Raskm42 said: I owned the Nordic retreat SE and while it was a nice dependable hot tub it doesn't have near the pressure of my new Hot Springs. Thanks, I kinda figured that it is what it is. I talked to Nordic and they were very helpful with just describing the air vents, how to adjust everything. etc but it really doesn't make that much of a difference. Lesson learned, but unfortunately it's an expensive lesson (and long term one). 🙂 Quote Link to post Share on other sites
Raskm42 1 Posted February 17 Report Share Posted February 17 I bought it brand new and used almost daily for five years and never any issues. Luckily I was the only one that used it and could direct most of the jets to my seat. Nordic makes a great hot tub. I sold with the house and wanted another Nordic but dealer no longer sold them so I bought the Hot Springs flair. Quote Link to post Share on other sites
CanadianSpaTech 424 Posted February 17 Report Share Posted February 17 @RDspaguy Upsize the impeller... I know this is generally a no no but this might be a case where it might be worth the risk...It's under warranty and if we keep it just between you and me...lol Quote Link to post Share on other sites
RDspaguy 646 Posted February 17 Report Share Posted February 17 Upsize just the impeller much and you will burn up the motor. Upsizing the pump assembly (motor and impeller) might work, but might burn up the pump or damage plumbing parts. I had a customer put in a higher hp pump and immediately blow the cap off of his diverter valve. Another blew a glue fitting at the manifold apart. Yet another collapsed his filters, or blew jets out in the spa. Others have had no issues at all, or it ran for a year before the motor went out. So, do you feel lucky? Roll them dice! A pump has a flow rating (gpm) and a head rating. Head is the resistance to flow built in to a system by height variances and plumbing/components. So the size and number of jets, size of pipe, size of filter, etc, is all part of the equation that determines which pump to use. Putting a bigger pump on a system is like running it with the valves half closed while simultaneously increasing the system pressure and vacuum. If the pump was undersized to begin with, it will be fine, but if not... 1 Quote Link to post Share on other sites
CanadianSpaTech 424 Posted February 17 Report Share Posted February 17 3 hours ago, RDspaguy said: Head is the resistance Long Live The Resistance! 1 Quote Link to post Share on other sites
ratchett 69 Posted February 18 Report Share Posted February 18 5 hours ago, RDspaguy said: A pump has a flow rating (gpm) and a head rating. Head is the resistance to flow built in to a system by height variances and plumbing/components. So the size and number of jets, size of pipe, size of filter, etc, is all part of the equation that determines which pump to use. Putting a bigger pump on a system is like running it with the valves half closed while simultaneously increasing the system pressure and vacuum. If the pump was undersized to begin with, it will be fine, but if not... The Escape SE has 30 jets with a 3hp motor. The Escape LS has 45 jets, with a 3hp and a 2hp CD pump. I'm thinking a larger motor/impeller will risk damaging the plumbing. Hell of a risk on a tub this new. 6 hours ago, heygreene said: Thanks, I kinda figured that it is what it is. I talked to Nordic and they were very helpful with just describing the air vents, how to adjust everything. etc but it really doesn't make that much of a difference. Lesson learned, but unfortunately it's an expensive lesson (and long term one). 🙂 Have you tried talking to your dealer? You are not a satisfied customer, maybe your dealer might be willing to work with you? Don't know what the chances, but it's better than being stuck with a tub which underwhelms. Who knows they might let you trade in your tub for the Escape LS model. Quote Link to post Share on other sites
Raskm42 1 Posted February 18 Report Share Posted February 18 8 hours ago, CanadianSpaTech said: @RDspaguy Upsize the impeller... I know this is generally a no no but this might be a case where it might be worth the risk...It's under warranty and if we keep it just between you and me...lol Lol....I didn't even know you could. Can you do that on a hot springs? Quote Link to post Share on other sites
heygreene 2 Posted February 20 Author Report Share Posted February 20 Update: I'm only really concerned with getting a good massage from the jets when it's either just me by myself, or me and my wife in the tub. For the last few nights I've just closed all other jets and opened the air vents for those 2 seats and it's been sufficient for us. While there's no "wow" factor at how strong the jets are, they do the job and have been relieving some sore muscles from all of the yard work we've been doing. One question: If the LS has a 3hp and a 2hp pump, and my SE only has a 3hp pump, how would that affect me if I had the LS? Would that just mean that instead of having to close off half of the tub jets to get it strong enough, it would be that strong with all jets open? I'd assuming it may even be more strong on the side with the 3hp pump, since it would only have to feed half of the tub instead of the entire thing. Quote Link to post Share on other sites
CanadianSpaTech 424 Posted February 20 Report Share Posted February 20 Just make sure you re-open the jets before getting out. If they remain closed the water will sit in behind the closed jet/waterfall and go stagnant and stuff will grow back there. 1 Quote Link to post Share on other sites
heygreene 2 Posted February 22 Author Report Share Posted February 22 Am I correct in my thinking above about the 3hp and the 2hp pump. Is the main purpose so that you don't have to close off any jets to get the full pressure out of each side? Thanks. Quote Link to post Share on other sites
CanadianSpaTech 424 Posted February 22 Report Share Posted February 22 Usually one pump works one half of the spa and the other the other half... then a lot of spas will have diverter valves where you can adjust the pressure of the said pump from say the lounger to the foot massage jets or an equal combination of the 2 if the valve is in the middle. Closing jets is not idea 2 Quote Link to post Share on other sites
