Tripping breaker
Ddonaldson7
Check for continuity to ground on your heater and equipment. Find that, and you've found the cause of the trip. Or disconnect one thing at a time until you find the issue.
Heaters tend to trip it immediately after reset.
If it trips with everything disconnected, pull the main wires off and see if it holds. It may be a bad breaker.
