Radius Cabinet Corner Panel
Hicks6
When redoing a cabinet I use beadboard stapled directly over the old cabinet. For corners I cut halfway through the back of the beadboard every couple of inches, spray with water and heat with a heat gun and bend it around the corner. You could also use shiplap installed vertically around the corner.
Cool, that's a good idea. I'll give that a shot if I can't get the direct replacement.
