DougA Posted February 6, 2021 Report Share Posted February 6, 2021 I have a 400 g. hot tub with Nature2, MPS and occasional adds of bleach because CYA is high (100 ppm). My combined chlorine is 5.0 in my hot tub. Free chlorine is a 2.0. Can I fix the combined chlorine with MPS? If so, how much should I use? Any other recommendations. Thanks! Doug Quote Link to comment Share on other sites More sharing options...
DougA Posted February 6, 2021 Author Report Share Posted February 6, 2021 I used the K-2006 with MPS regent to get the CC readings so I'm guessing they are right. Confirmed 5.0 with two brands of test strips too Quote Link to comment Share on other sites More sharing options...
duckcmmndr Posted March 18, 2021 Report Share Posted March 18, 2021 Your CYA is way too high. WIth a CYA of 100 you will need to maintain a FC level of 8-13 to keep it sanitized and will have to raise it to 39 to shock it. I would started by draining atleast 2/3's of the water out to get the CYA down to 30 or so. If it were me...I would drain it all and start over. Quote Link to comment Share on other sites More sharing options...
