mscdman Posted February 2, 2021 Report Share Posted February 2, 2021 I’ve got some interesting data/test results I’ll be sharing soon but have been noticing some odd things on my new tub. Background: seeded 15-30pm bromide salts. No floater. Oxidizer. Tub used every other day. Ah sum purged prior to fill ~1 month ago. started adding 2tsp of 1-step (85% dichlor and 15% bromide) after every use. Findings per previous posts and steps were that after use it would raise the bromine to about 10-12ppm. I’d skip a day and when using the day after the skip the bromine was about 4ish when I’d use it. So about an 4ish ppm drop/day. Anyway I continued this way for a few weeks - with CYA being added as a byproduct and after testing CYA for about 3 weeks - CYA in the normal range. This week I’ve switched to bleach 7.5% concentrate. Adding ~3oz (which is oddly more than should be needed per pool calculator) after each use is bringing bromine up to 10-12ppm (as it was with the 2tsp of 1-step) (FYI - I should only be needing 2.1oz of 7.5% bleach to achieve this bromine level- maybe the 1 month of CYA levels is hampering this?) anyway ....here’s the odd thing. When using the 1-step above after the skipped day it was still at 4ppm. Now after switching to bleach with a level of 10-12ppm after use, when coming back after the skipped day the bromine is 0. why would this be different using the 1-step vs bleach? @dlleno@chem geek Quote Link to comment Share on other sites More sharing options...
