Greenerboy Posted February 1, 2021 Report Share Posted February 1, 2021 Hi I'm reposting this as i think i uploaded it to the wrong thread. I'm Hoping some clever person can help me. I have an MSPA Soho and it has developed a fault. If i turn it on without heater, all functions run and it stays on. If i turn the heater on it runs for a few minutes and then the display goes off and the functions shut down. The buttons on the display are still lit but not the display itself. If i drop the heater temp below the current temp the heater stays on but is obviously not trying to heat the water. There is no fault code displayed. Prior to this i noticed this fault happened once every so often maybe once every couple of weeks and i would turn it back on and it would be fine. I did notice that it took a long time to heat about a month ago when it turned itself off and the temp dropped 10 degrees. Any advice gratefully received Quote Link to comment Share on other sites More sharing options...
Stevo 122 Posted April 23, 2021 Report Share Posted April 23, 2021 Hi there. From what you said above it sounds to me like it could need a new heater or it could be a sensor that might need replacing Quote Link to comment Share on other sites More sharing options...
