Borat1987 Posted January 31, 2021 Report Share Posted January 31, 2021 My hot tub has developed a fault where it wont display the temperature saying “temperature unavailable” in the app then it says “no flow condition”. Its a Gecko control panel etc. I’ve had a look inside and seen that the heat pump ozonizer has burnt out! Would this be the issue or is potentially a separate issue/symptom of a bigger problem? Would you recommend replacing both the heat pump ozonizer and the flow through heater? Quote Link to comment Share on other sites More sharing options...
