2001 HotSprings Sovereign Mystery Leak
Gunner308
Good evening,
I recently purchased a 2001 Hot Springs Sovereign Hot tub and it has performed flawlessly until about a week ago when I noticed water seeping from the front right corner. I have taken the panels off and started clearing away the foam and to my surprise, no moisture is present but towards the base. I am still digging at the jet lines to ensure no leaks are present. But it almost seems as if the water is coming from the vent pipe. Is this possible? Should I attempt to lay the tub on it’s side and investigate? Any help is greatly appreciated.
BTW, I have added photos of the actual moisture area to illustrate how confined it seems to be.
Hello, I have the 2010 Sovereign II. I had a mystery leak in the corner. In this corner of the tub there is the dual jet on 'moving snake' that sits behind a cover. Inside this compartment area is a small led light at the bottom. This  led light hole is what was leaking for me. I thought for sure it was a pipe but it ended up being this light hole and I have just caulked it to stop my leak.
