Freeze protection
Wlt219
You should be able to adjust the temp sensors though the menu.  Be careful not to over calibrate them.  And be sure you are getting an accurate temp reading from where the freeze sensor is.  Not necessarily what your weather app says it is, or even the thermometer out on your porch.  Freeze damage usually costs more than running the equipment to prevent it.
Another note The freeze protection routine in the Aqua-Link (I think) will come on at 34 to 36 BUT wont turn off until it reaches 38. with no adjustment.
  • Like 1
