Wlt219 0 Posted January 24 Report Share Posted January 24 My pool is in freeze protection mode. IAqualink says air temp is 34° when in reality is 42° and i can't turn it off Quote Link to post Share on other sites
RDspaguy 632 Posted January 24 Report Share Posted January 24 I'd guess that your air temp sensor is bad, but I am no expert on these. @jimmythegreek, @Pool Clown any suggestions? Quote Link to post Share on other sites
jimmythegreek 23 Posted January 24 Report Share Posted January 24 Not too familiar with jandy but the first place to check is the air sensor as RDspaguy noted Quote Link to post Share on other sites
Pool Clown 10 Posted January 29 Report Share Posted January 29 You should be able to adjust the temp sensors though the menu. Be careful not to over calibrate them. And be sure you are getting an accurate temp reading from where the freeze sensor is. Not necessarily what your weather app says it is, or even the thermometer out on your porch. Freeze damage usually costs more than running the equipment to prevent it. Another note The freeze protection routine in the Aqua-Link (I think) will come on at 34 to 36 BUT wont turn off until it reaches 38. with no adjustment. 1 Quote Link to post Share on other sites
