lindner115 Posted January 21, 2021 Report Share Posted January 21, 2021 Got around an 2006 vita spa nuage. Just purchased. works good other than every afternoon temp is blinking. I run diagnostics and comes up P1, pump 1 issue. I'm thinking whatever is supposed to trigger HEET feature on pump 1 isnt triggering. So the temp keeps going down till i reset daily. Is there a fix without replacing the pump. Any help appreciated. Thanks. Lindner115 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted January 21, 2021 Report Share Posted January 21, 2021 Vita Spa (DM Industries) are a different kind of bird. not my favorite. I would check the pump connection at the pack and make sure it is not loose. Make sure it is not in economy mode. Some of their systems use a circuit board "card". A circuit board that plugs onto the main board. One for lights one for audio one for pump functions. Remove the pump related card and make sure there is no corrosion on the brass connections. Would need to see photos of the circuit board and the schematic on the inside cover to be of any more help. FYI.... Circuit board is likely made by http://www.consumerengineering.com/ Website is a bit of a mess. Don't think they are still in business but unsure. 1 Quote Link to comment Share on other sites More sharing options...
lindner115 Posted January 22, 2021 Author Report Share Posted January 22, 2021 This the board. I’ll do some more checking. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted January 22, 2021 Report Share Posted January 22, 2021 1 hour ago, CanadianSpaTech said: Vita Spa (DM Industries) are a different kind of bird. not my favorite. That's one way to put it. 😉 Quote Link to comment Share on other sites More sharing options...
