mscdman Posted January 18, 2021 Report Share Posted January 18, 2021 Are there any electrical shock dangers of using the outdoor tub with GFCI disconnect WHILE snowing? Theres no way for the electricity to arc from the disconnect box through the snowflakes to me in the tub is there? im probably just over reacting. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted January 19, 2021 Report Share Posted January 19, 2021 The snow is not an issue, but you should not use the spa without a gfci. Under the wrong set of circumstances it could kill you just for touching the water. There is a very good reason they are required by electrical code. Quote Link to comment Share on other sites More sharing options...
mscdman Posted January 19, 2021 Author Report Share Posted January 19, 2021 I’ve got the GFCI 1 Quote Link to comment Share on other sites More sharing options...
