Safe to use outdoor tub while snowing?
Are there any electrical shock dangers of using the outdoor tub with GFCI disconnect WHILE snowing?
Theres no way for the electricity to arc from the disconnect box through the snowflakes to me in the tub is there?
im probably just over reacting.
Link to post
The snow is not an issue, but you should not use the spa without a gfci. Under the wrong set of circumstances it could kill you just for touching the water. There is a very good reason they are required by electrical code.
Link to post
