rmcderm313 Posted December 15, 2020 Report Share Posted December 15, 2020 Hi All, I just filled my hot tub (700 Gal)with fresh water. I'm planning on using the dichlor/bleach method. I tested the TA, pH and CH as follows (with the Taylor K2006 kit): TA = 60 ppm pH = 7.6 CH = 70 ppm I added 3.1 oz calcium chloride and then 3 oz. of sodium bicarbonate to raise the TA and CH respectively. After a few hours I tested again: TA = 80 ppm (right where I want it I think) pH = 8.0 (too high) Acid demand = 1 drop CH = 120 ppm (sufficient, I think) I've tried to lower my pH back down by adding 1/2 oz of Sodium Bisulfate. After an hour pH is still testing at 8.0. I just added another 1/2 oz. and will test again after running pumps for 15 minutes (recommended on the package). Did I try to hard to get the CH and TA in check? Should I have left them where they were? I haven't added any dichlor yet. Should I wait until my pH is good before adding sanitizer? or do I need to get some sanitizer in the tub ASAP? No one is using the tub until my chemicals are good. Any advice on getting back to a good TA-pH,CH is appreciated. Thanks, Rob Quote Link to comment Share on other sites More sharing options...
rmcderm313 Posted December 15, 2020 Author Report Share Posted December 15, 2020 The second addition of Sodium Bisulfate also did not reduce pH. In fact I think the color is a bit 'redder' in this test. Help! Rob Quote Link to comment Share on other sites More sharing options...
rmcderm313 Posted December 16, 2020 Author Report Share Posted December 16, 2020 I added 1.7oz of Dichlor and my pH fell back to between 7.4 and 7.6. For right now I'm good. When I test for Chlorine demand in 24 hours, I'll check for pH again to see how things are. Rob Quote Link to comment Share on other sites More sharing options...
